Hello
I am new to this forum but have been reading the forum as a guest to gain information about these cars.
I have at the moment a Picasso 2.0hdi which due to corrosion of the sill I have let go. Painful as its got 5 good tyres fronts and spare brand new rears 7000 miles only so will these wheels fit a berlingo. Can a 2.0hdi fit a 1.6hdi? Thanks and keep up the good work .
Welcome to the forom Derek!
Hi Derek and welcome. What size are the Picasso wheels - bore, no. of holes, offset?
Hello Derekg welcome along to the forum. Smile
(16-05-2016, 09:13 PM)Jed Clampit Wrote:  Hello Derekg welcome along to the forum. Smile
Well I got me a partner and swapped the wheels over , the battery as well . Took it for a MOT only failed on a couple of things , number plate bulb, horn and slightly over emissions. Did not think that was bad seeing the car has sat for 2 years . So will be changing the fuel filter and air filter , running some injector cleaner through. Bulb changed already . Horn needs investigation when the rain stays away for a couple of hours. Picasso will be broken and I have got myself an engine for use at a later date.
Bulb was my fault as I was so engrossed in making sure all indicator bulbs were the right colour forgot to check number plate bulbs completely and horn I did not even think about, that's the trouble when you get older LOL. Huh
When the rain stopped I was able to get out and rectify the light and changed the fuel filter also running some catacleaner through. But the horn was a little bit perplexing as to where it was, first I removed the mud guard n/side and proceeded to remove the bumper when i had a thought of removing the n/side headlight. I was able to do that because I had the mud guard out of the way and I could see up and find the bottom bolt for the h/light , once out I find the horn and lo and behold not even plugged in. So today Monday I took it for the retest and come away with a clean bill of health , no advisories. Result.
Not bad for a car which had stood in a garden for 2 years and cost me to buy £250.00.
Diagbox 7.57 download
Today 09:13 PM
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
