Roof rails / bars
I've seen a picture of a B9 , it appears that the roof rails had been placed in a roof bar position, is this possible with mine or am I mistaken ?
[Image: 2c29e917675d9ffad97fb7148f95273d.jpg]
Sent from my BUSH 5 Android using Tapatalk
Hi doofer,
Yes mine has the glass roof, so it looks like I can rotate them.
They are fixed with torx type screws , anyone know what size it is ?
Mark
I believe the tool for the roof bars is in with the wheel changing bits?
Thanks Trevor,
I've located the tool and tested them.
Well happy as that's saved me the cost of roof bars which I was about buy.
Roof box next !
Mark
It's such a simple effective design. When across the vehicle the bars are fairly close together so not ideal for very long ladders but for occasional use it certainly saves the cost of a roof rack.
Along with the glass panels and storage it was the reason I wanted a Modutop.
It's a good package, I'm taking my Berlingo to the black sea and back this year and all the storage is very useful !
Mark
(16-05-2016, 03:11 PM)Satellitemark Wrote:  Thanks Trevor,
Roof box next !
Mark
Hi Satellitemark, I just got a2012 Berlingo with rusting (the amount of rust says there are cavities) roof rail fixing holes. The dealer says he'll fix them next week, but some casual comments are goading me to fix it myself.
What size are the screw threads? A 6mm bolt drops through and an 8mm is too tight so it has to be an oddball - 7mm .... ?
I've already ordered a handfull of 7mm x 20mm hexagonal bolts to plug the roof holes and later make my own rack if needed, after blasting out the rust, applying converter and sealing with the bolts and O-rings and/or nylon washers. My Berlingo came with 5 of the 6 holes plugged with feeble plastic caps that let in water and dirt. The dealer admitted its an oversight by Citroen. My friend's 2009 Berlingo had no sealing caps or plugs from new and rust has started in some holes.
   Have others had this problem?
Dave
Hi Dave ,
I have no rust that I know of, the screws that I used the tool on fix the rails to the mounts, I've never taken the mounts off, as Ive not needed to, so I've not seen the body holes.
Mark
Roof box next !
Mark
Careful what you put on them as the weight limit is a lot lower than for roof bars on a metal roof as it can damage the roof seal on the modutop overloading it.
Thanks for the info, any idea what the weight limit is ? Or where I can find out, as I don't have a lot of faith in asking the dealers.
Mark
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
