Threads: 9
Thanks Received: 3 in 2 posts
Thanks Given: 2
Hi,
I am getting a knocking noise from the front n/s suspension area.
I have replaced the drop links and also the lower wishbone was replace about 3 years ago.
Any ideas on what else it might be?
Martin
Threads: 147
Thanks Given: 263
11
Following on from Wavin, check if its the CV Joints by doing full lock turns somewhere open. Could be one of the mounts.
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
Check the track rod ends. Mine were shot and as surprising as it sounds, replacing them stopped the knocking.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 2
Hiya Dude, Mine was doing this but on the O/S. I checked the underside and discovered that the Anti roll bar connecting link was shot. 13quid from eurocarparts
Threads: 32
Thanks Given: 13
Smudger
It might be worth replacing the pair.
I did mine and within a month the other side went. I read that it was recommended to renew them as a pair.
Threads: 32
Thanks Given: 18
After checking all of the above, don't forget to check for play in the ball joint.
Threads: 2
Thanks Received: 1 in 1 posts
also cheeck top mount on suspension leg
Threads: 9
Thanks Given: 2
I replaced the lower wishbone arms again and that stopped most of it. I think there was a steering rack issue on one end but not to worry now.
thanks for all the advice.
martin
