  • 22 Vote(s) - 2.91 Average
1.6Hdi rough idle on startup
My 2008 1.6Hdi Berlingo van has developed a rough idle upon startup from cold along with signs of blueish smoke. The van has never failed to start and once warm there is no problem.
I have never seen the pre-heater light come on, but I believe that is common with this engine unless temperatures are really cold.
Any ideas? Thanks.
What Berlingo do you have?
http://www.berlingoforum.co.uk/showthread.php?tid=31
[-] The following 1 user says Thank You to pk7478 for this post:
  • Johny555
it's a 2008 Mk2 Berlingo van with the 1.6Hdi engine, 90bhp
I have exactly the same symptoms, 06 plate 1.6HDi
Those in the know..... Go Berlingo!
I suspect a leaky injector. If one is dripping slightly it will pool in a piston, cause it to misfire, and then burn off cold with a puff of smoke.
Could be a dodgy injector or air being drawn into the fuel system, prone for pipes rubbing under air box and dragging air in
Last Post: deejay_xb
Today 05:48 PM
» Replies: 30
Last Post: Beaumotor
Yesterday 04:38 PM
engine light
Yesterday 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
