[Engine] rubber pipe hanging down from front of sump and blower intermittant
Thanks Given: 4
Good afternoon, my girlfriend has a 54 plate berlingo multispace 2.0 hdi and we have few questions if anyone can help.
The first is we have noticed a small diameter black rubber hose hanging down from infront of the sump visable looking from front of car, should this be hanging down or connected to something?
Secondly now and again we loose the blower inside the car it just stops working then all of a sudden come back to life bit tricky when windows steam up.
Lastly the engine management light intermitantly comes on then goes off after a day or so.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Not sure about pipes hanging down can't see any on mine,engine light best get it looked at,to see what's going on ,shouldn't flicker on,
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
Your pipe hanging down could be the drain for the fuel filter , does not connect to anything at the bottom , used for draining water out of the fuel filter.
Thanks Given: 4
(23-05-2016, 06:36 PM)Johny555 Wrote: Not sure about pipes hanging down can't see any on mine,engine light best get it looked at,to see what's going on ,shouldn't flicker on,
Light was on when we went for mot last month and garage said it was due poor fuel, gave it a full service and told us to put redex through it and change where we fill up with fuel, which we did but now just comes on for a day or so and goes off and no sign for a upto a week, we are limited where we can fill up as with live in a village and petrol stations are a little rare, a good run down the motorway seems to get rid of it too, can poor fuel do that or is it sensor problem? where is it best to avoid filling up with diesel if it is poor fuel, doesnt sound quite right lol
Thanks Given: 4
(23-05-2016, 07:13 PM)brodfather11 Wrote: Your pipe hanging down could be the drain for the fuel filter , does not connect to anything at the bottom , used for draining water out of the fuel filter.
never notice till cleaned it other day thought something had fallen off or got catch up there, It has a brown tinge to end of pipe so it looks like somethings running out of it, if it nothing to worry about that great thank you
Threads: 67
Thanks Given: 237
50
Possibly the drain from the battery tray plastic insert ( if still fitted ).
Serieal Berlingo owner
• Anthony Hall
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
EML can be caused by many things. The best solution is to get fault codes read and post them up for more help.
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• Anthony Hall
Threads: 8
Thanks Received: 6 in 6 posts
Thanks Given: 1
18-06-2016, 10:50 AM
(This post was last modified: 18-06-2016, 10:50 AM by Vossy1.)
(23-05-2016, 09:51 PM)Col Wrote: EML can be caused by many things. The best solution is to get fault codes read and post them up for more help.
I've have a 56 1.6hdi from new, can't tell you what it's for without looking but the black pipes been there since new, so I wouldn't worry about it.
Threads: 0
Thanks Received: 8 in 7 posts
Thanks Given: 2
(23-05-2016, 04:59 PM)Anthony Hall Wrote: Good afternoon, my girlfriend has a 54 plate berlingo multispace 2.0 hdi and we have few questions if anyone can help.
Lastly the engine management light intermitantly comes on then goes off after a day or so. "noticed a small diameter black rubber hose hanging down from infront of the sump" Its definitly a drain hose. There should be an undertray fitted to the 2.0l so you would never usually know about the hose unless you do your own servicing. I only found out about it when mine came back from Mot and service without the undertray, the garage had forgotten to re-instal it(!) There maybe some components that require protection on these lumps as they seem to be quite low to roadsurface. Why else would undertrays be fitted? (genuine question)
Threads: 8
Thanks Received: 5 in 5 posts
Thanks Given: 17
Small pipe maybe Airconditioning condensation drain for fan coil ( inside part)
Are no codes shown with engine light? Maybe particulate filter? Needs regen, hence disappears after motorway run
Sent from my 3geesus using Tapatalk( it's ifail)
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
