[Warning Light] flashing battery light
2003 berlingo multispace forte 1.6 petrol manual-----does anyone know or had the battery warning and centre display and interior lights flash on and off after engine switched off and keys out of ignition? there was also a clicking noise near the ignition barrel area. took my car to garage fault hasn't come up when I dropped the car off (sod's law!) garage plugged in diagnostics reader no faults apart from headlight minor fault. anyone got any suggestions first time on here so any help would be very much appreciated
thanks
Sorry but the only time my interior lights flashed on/off was when I had not shut a door properly.
[-] The following 1 user says Thank You to Trevor for this post:
  • Tristan Mead
Have you checked the alternator?
I had the battery light on my 1.6 petrol when it was failing.
[-] The following 1 user says Thank You to tucker for this post:
  • Tristan Mead
Did the garage do a battery/alternator check and BSI reset first?
(25-05-2016, 06:15 AM)Hi thanks, will check with the garage but the problem seems to be very unpredictable as the fault stopp  ed when I dropped the car off, so I guess it\s hard to know what Wrote:  Did the garage do a battery/alternator check and BSI reset first?
(24-05-2016, 02:01 PM)Tristan Mead Wrote:  2003 berlingo multispace forte 1.6 petrol manual-----does anyone know or had the battery warning and centre display and interior lights flash on and off after engine switched off and keys out of ignition? there was also a clicking noise near the ignition barrel area. took my car to garage fault hasn't come up when I dropped the car off (sod's law!) garage plugged in diagnostics reader no faults apart from headlight minor fault. anyone got any suggestions first time on here so any help would be very much appreciated
thanks
Hello Tristan and everybody else!
I'm new to this Forum. I've just bought my second Berlingo - a 2004 2.0 HDI and I'm very happy with it, apart from when I first got it a couple of days ago, I had exactly the same problem as you have described above - when I have finished driving it and turn the ignition off and take the key out of the ignition, the battery warning light has been flashing and the internal lights and digital display on the dashboard have been flashing, along with a strange clicking noise.
However, touch wood, it does seem to have stopped doing it now after a couple more days of driving it around. I'm hoping that maybe the battery was just a bit flat when I first bought it and now that it's charged up a bit after being driven around, it's working as normal. Fingers crossed!
Or, is this a common problem which others have had too?
Cheers!
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
