Threads: 2
Hi Guys
Has anyone ever had any success filling pin holes in a sump?
I have 2 tiny holes right at the front that seep oil very slowly in my 2006 1.9D
Threads: 20
Thanks Given: 2,126
18
You can repair it but the oil causes a problem.It has to be oil free.There are compounds around for the job.Is a new sump horribly expensive?
Strawberry flavoured windows
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Had that with my old combo,new oil change then sump decided to leak,replaced sump and just put the old oil back,because the oil was only about a week old,
Threads: 2
The holes are high enough up the sump that Im confident that I can clean all the oil and crud from the area enough to get a good bond so I will give it a go before spending anymore cash and get back to you all.
Threads: 9
Thanks Given: 316
15
Wash the sump off with some brake wash first
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
If it's a steel sump with pin holes you'll be chasing them! It's rust and will just go somewhere else within months id bet! You'll have to drain the oil anyway, just catch it and put it back in with new sump, brake cleaner will seep in the holes and then dilute the oil on the inside making it thinner and more prone to running out, enjoy your fruitful task, this is one occasion where do a job once do it right is very applicable
The following 1 user says Thank You to dumdum for this post:1 user says Thank You to dumdum for this post
• ron
