  • 20 Vote(s) - 2.5 Average
Boing - ing noise from suspension
Hi everyone could i please have your help,
recently my berlingo has started to make a boing - ing noise from what sounds like the rear of the car it is confusing me because it sounds like the noise of a spring but i cant see any springs at rear.
Also it tends to do it when setting off after realising handbrake and rear of car goes down under acceleration and it also does it when going over bumps but not all time. it seems to have only started doing it after we took our caravan out for the first time to tow with it and the caravan isn't too heavy for the car. some people have said check front springs but i havent yet but the thing is car has just passed it test.
any help would be greatly appreciated
Many thanks Matt
I've a similar thing on my 04 2.0hdi. I've decided it's brake related, sounds like a spring releasing late, so I'd also be interested to here any suggestions as to what to look for.
It might be spring linked to load sensing valve for brakes.
2003 Citroën Berlingo 2.0HDi Multispace Desire
Hi guys I have thought about the brakes myself but why would the bumps cause it also where is load sensing valve and what does it do I believe its something which makes the brake better when laden up, thanks again
Hi Matt,
I had the same problem with my 2003 berlingo.
It kept going boing untill the front spring snapped.
I took the cat to my local Auto point centre and had both front springs replaced.
I was warned not to go through big puddles in the future as it starts to rot the springs.
Your problem may not be the same as mine, so i would reconend that you take the car to a local centre and ask them to investigate. It should not cost you anything, but will give you an idea what is wrong.
Diesel.
(28-09-2011, 09:13 AM)diesel fuel Wrote:  I took the cat to my local Auto point centre and had both front springs replaced.
The poor moggy!! :lol:
Mine does the same over speed bumps. It's definitely the rear end of the car.
It's not got worse or caused any problems and passed it's MOT, so I just put it down to age of the car!!
its the spring on the load sensing valve,it wears a groove in the end which then sticks and then boings when you move.its behind the offside rear wheel(uk)work the valve with your hand and you can see this happen.just bend the end to a circle and job done! hope this is of use and works for you !
Thanks Guys for your help i am going to have a look tomorrow at all your possible suggestions but in the meanwhile keep them coming
Thanks Again
Matt
hey up folks,
I have had a look at the front springs and they seem fine with no signs of rust but i have tried looking for the load sensing valve and cant seem to find it, do i need to jack the car up with the rear wheels off?
thanks again for support so far
(27-09-2011, 08:26 PM)BerlingoHDI Wrote:  Hi everyone could i please have your help,
Many thanks Matt
its easier with the wheel off but jacking up to get underneath car is a must,it is on the chassis inside the main member above the axle.hope photos help....
Attached Files Thumbnail(s)
[-] The following 3 users say Thank You to lorraine for this post:
  • bob_CBR, colinh, Ol'Jeffers
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
