Thanks Given: 3
Hi guys
Probably been asked a thousand times but here goes MK 2 1.9 d with DW8 gearbox (I think)
Clutch pedal bites about 2cm off the floor, been like this ever since I bought her 2 years ago.
About a year ago it started having difficulty engaging gears when warmed up so changed the cable and she was good for about a week until the cable stretched a bit and then it was back to just off the floor and making a slight rumbling sound when dipped.
So do I need a new clutch even though it doesn't seem to slip (pulls like a train up hill in 5th) ?
Release bearing ?
Actuator arm ?
Or another cable ?
Any help would be greatly appreciated as funds are a bit scarce at the moment and I don't want to spend a small fortune if it could be something simple
Threads: 9
Thanks Given: 316
15
If the clutch is adjusted correctly - is it an auto adjuster?
Yes clutch and everything you have identified apart from the clutch cable should be ok because you changed that.
• Tonybasshead
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
What you may find is the release bearing has cut through one or more of the diaphragm *fingers* so the clutch doesn't release properly.
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• Tonybasshead
Threads: 10
Thanks Received: 8 in 8 posts
Thanks Given: 8
Was it a pattern part cable you fitted or a genuine citroen one. Pattern ones are cheap for a reason and do stretch
Sent from my SM-G900F using Tapatalk
The following 1 user says Thank You to Yorki for this post:1 user says Thank You to Yorki for this post
• Tonybasshead
Thanks Given: 3
Cheers Ron
Any ideas what would cause the low bite then ? Literally about 1 cm off the floor and cable is genuine citroen and there's no signs of any brackets being bent. She's just past 100,000 miles on an 06 plate but was made in 05 found that can make a difference when buying parts ?
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
Sound like you'll be needing a new fork or clutch kit (I'd do both, but not at dealers!! Find a decent aftermarket and you'll get that done for 3-400 quid depending where you are in the country...
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 4
I had a Pug 405 with 300k on the original clutch/gearbox.
The clutch was heavy and low but never used to slip.
Never drove it when it was nice and fresh.
I always thought they were all like that? Not sure if the 95 Pug 405 1.9 TD had the same gearbox though.
Silver Berlingo Multispace 1.4i Forte
