  • 22 Vote(s) - 2.95 Average
Remote Central Locking
I have just been given a new 61 plate berlingo from work WITHOUT remote locking, lol.
what i want to know, is it easy enough to fit the remote locking on either from citroen direct eg, is it just a case they sell you a fob plus the programming???? or can i fit an after market one like a toad RK30??
If so has anyone done it that could provide some help as to fitting etc, im fairly handy with a soldering iron and heatshrink, just need to be pushed in the right direction.
To install fully factory remote locking system is expensive.
It's better to install aftermarket door actuators but control system.....
you can use original (key transmitter+battery+reciever).
If there's no reciever in a Com2000 unit you must change whole unit.
After all these installations option "central lock" must be activated by Lexia.
(28-09-2011, 09:24 AM)pk7478 Wrote:  To install fully factory remote locking system is expensive.
It already has central locking, just no remote, its optional, all i want to do is have keyless entry.
You wanna do it by yourself ?
(28-09-2011, 04:00 PM)andymiller6891 Wrote:  It already has central locking, just no remote, its optional, all i want to do is have keyless entry.
If the sensors are fitted then you should just need the key & programming. Not cheap from a dealer - mine quoted me about £140ish (£70 for the key & another £70 to program it). If you get the key you could have it programmed somewhere else for a lot less.
Quote:If the sensors are fitted then you should just need the key & programming. Not cheap from a dealer - mine quoted me about £140ish (£70 for the key & another £70 to program it). If you get the key you could have it programmed somewhere else for a lot less.
how would i know if the sensors are there???
Pop in to your local dealer.
Sent from my GT-I5700 using Tapatalk
VIN to PM
Quote:VIN to PM
Where would i find the vin, is it on the plate under the bonnet???
It's on your V5
Users browsing this thread: 2 Guest(s)
A Testing Question....
Today 03:03 PM
Wheel nuts
Today 10:16 AM
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
