I just lost 5th gear
All other gears are fine just no 5th any info welcome.thanks
Linkage??
Maybe the clip or roll pin fallen out of 5th gear mech. Drain the oil and take the end cover off (3 or 4 bolts) and have a look. It should be obvious if there is a prob.
  • brajomobil
As said above by Col, quite common for the large nuts to work loose on the ends of the gear assembly, this in term allows too much movement , & all,the teeth get stripped off the gears .
A relatively simple fix if this is the case.
[-] The following 2 users say Thank You to Lighty for this post:
  • Bigt, brajomobil
(01-06-2016, 05:48 AM)Lighty Wrote:  As said above by Col, quite common for the large nuts to work loose on the ends of the gear assembly, this in term allows too much movement  , & all,the teeth get stripped off the gears .
Thanks for the replys is it box out or can it be done in situ.tony
Thanks to lighty for the info job done I replaced the 5th gear hub and nut and it's all good.thanks very much
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
