Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 4
Hi all
Just joined the forum. Got a 2007 Berlingo today, done 173000 miles but seems fine. Anything I should look out for?
I look forward to joining in conversations etc.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Engine size? Diesel .petrol? Oh and welcome
Threads: 2
Thanks Given: 4
Doh! That would have been useful.
1.6 HDi diesel.
Thanks Given: 8
5
A lot say bad turbos, leaky injectors,Doggy electrics,regular oil change a must,good service history,I bet you wished you never asked now,!!,
Threads: 9
Thanks Received: 26 in 21 posts
Thanks Given: 19
Keep an eye out for leaky injectors and make sure the oil is changed on time, with the correct oil.
As yours has already got to 173k, it's either been well looked after anyway, so you've nothing to worry about, or its had all the bits that break replaced when the oil isn't changed on time (injector seals, turbo) so you've nothing to worry about.
It should have had a timing belt change at 10 years or 150k..
Sent from my SM-G925F using Tapatalk
Threads: 2
Thanks Given: 4
Thanks guys.
It's had a belt change but not sure when.
Silly question. How do I tell if the injectors are leaky?
