Odometer fine but no speedo.
Hi,
1. Month ago I had some Type of sheet metal wrapped around the timing belt pullies which I removers. Not sure if the metal came of the van or picked up from the road. There has been a whirring noise ever since, not a problem but may be relevant to the problem.
2. The odometer displays but the speedo fails after the engine starts to warm up and the mileage doesn't change when the speedo dial fails. If I co 70mph+ the whole of the dials/warning light/odometer display goes blank.
3. Acceleration is a little abrupt when accelerating from low revs. This has become noticeable since the timing pully problem.
I'm thinking there may be some kind of sensor for the speedo I could check? Or the local wiring to it? Where would I find it?
Any ideas?
Thanks Lee.
you may want to try change this,not expensive from Citroen,easy diy fit if you can get underneath,just up the rear of the gearbox,mine went,same symptoms with the clock plus sometimes it didn't seem to have the turbo,other times it was fine,changed it and all back to normal,mines a 1.6hdi van on a 58 plate.
[Image: a%20switch_zpshoinrepm.jpg]
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
Thanks Ian, any idea what the part is called?
Mines a 55 plate 2L HDI on 170000 miles. Do you think the part will be in the same place?
Lee.
it will be in that area yes,but looking on ebay it's a slightly different shape on the 2ltr, it's the speed sensor, sends signals to the clocks and ecu ( the ecu bit i didn't realise,but it could explain the performance some time).. hope it clears it up for you,I'll watch this space..Ian.
Top man, I'll get to the motor factors.
Lee.
Let's us know if it sorts it out,always like to know if the problem gets solved,cheers
(06-06-2016, 01:28 PM)Totsy Wrote:  Top man, I'll get to the motor factors.
Lee.
I had to visit the stealers for mine,wasn't bad actually haha
Will do Johny555. I've ordered the part from eBay. The motor factors don't sell them, said I'd need to go to Citroen. I think it was £11. Try and replace it this week.
Lee.
Well got the part but the only wire and plug I can see anywhere on the gearbox is at the rear between the box and the bulkhead with a three pin plug attached. The part I have is completely different to the sensor the plug fits onto on the car other than they are all three pin plugs/sockets. I've taken a picture I'll try and post it.
Lee.
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
