[Filters & Oil] filter removal
hi guys just done my 6monthly oil change and I had bit of a problem getting the paper oil filter out of the housing,it  seams to clip into some lugs what are at the bottom of the filter housing,in the end I used a trick I seen on youtube, a guy used the cardboard tube thingy that is in the centre of a toilet roll, don't laugh ha ha, it really works, but has anyone made somethink more substantial maybe out of tin or plastic, would like to know, or would it do any harm to cut the lugs of in the housing so the filter just pulls out dead easy ?
It's designed that way so that as you unscrew it, it lifts the plug out of the drain hole so there is only minimum oil left in the housing, I'm not saying it is a brilliant design, but once you understand it it works fine.
As to removing the filter from the housing, a good pull with hands wearing disposible plastic gloves works ok. There are other threads explaining how to, and how not to, fit the new filter.
cheers solent the force needed to pull mine out is ridiculous got to be a proper way, I would have been knackered only for the bog roll thingy.
Give it a sharp tug - they are all like that sir!
Last Post: allanr
Today 06:16 PM
Last Post: allanr
Today 05:57 PM
Oil consumption at 200K miles
Last Post: Buki
Today 08:29 AM
Forum activity
Yesterday 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
