[Engine] 1.6hdi immobilisor
Hi all. Just bought used M-S Forte 1.6hdi 2006.Lovely to drive. Went in for full service, drove home and car will not even turn over completely cut out... Diagnostics said take off battery leads for 20 minutes reconnect. It worked. 2 more days same thing again. Would not turn over completely dead. This time battery disconnection did not work. Diagnostics said try other key and it worked. Remote locking locks but has never unlocked. Now going through test the keys to see if they work and then engine diagnostics. No fault codes coming up. HELP.......!!!!!!!!
(10-06-2016, 08:12 AM)olderone Wrote:  Hi all. Just bought used M-S Forte 1.6hdi 2006.Lovely to drive. Went in for full service, drove home and car will not even turn over completely cut out... Diagnostics said take off battery leads for 20 minutes reconnect. It worked. 2 more days same thing again. Would not turn over completely dead. This time battery disconnection did not work. Diagnostics said try other key and it worked. Remote locking locks but has never unlocked. Now going through test the keys to see if they work and then engine diagnostics. No fault codes coming up. HELP.......!!!!!!!!
When you turn your key for start and you hear only "click" then your starter motor is bad or your battery is bad.
Try with new battery if that does not help then you have to replace starter motor graphite bushes.
Best regards,
brajomobil
[-] The following 1 user says Thank You to brajomobil for this post:
  • olderone
Thank you for advice. Bypassed battery and that did not work. There is no click..it is just dead. Will try the starter motor.
(13-06-2016, 09:45 AM)olderone Wrote:  Thank you for advice. Bypassed battery and that did not work. There is no click..it is just dead. Will try the starter motor.
You can bang it hard with hammer. After that if it turns and starts the motor
then definitely it's the graphite brushes.
Best regards,
brajomobil
Best regards,
brajomobil
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
