No crank no start need help please
I have a berlingo 2003 1.4I multispace was working 100%
When I turn the key to on the relay under the bonnet buzzes
Then when I turn it to start the car the buzzing stops but nothing happens
Then when I let the key return to on the relay starts buzzing again
So in my mind the relay is faulty and that means changing the circuit board but I would like any other suggestions as to what it could be or what could of caused it in the first place.
Could it be something else that's making the relay do this?
Thanks in advance
Are you sure the battery isn't flat?
bad earth, loose connection, flat battery
2012 Berlingo Multispace VTR 1.6HDI White
Starter motor?
2001 1.9D Multispace.
Hi guys thanks for your reply
As soon as the problem occurred I broke out the multimeter readings as follows:
Battery was 12.2v which I thought was a little low.
Crank voltage drop to 11.6 which is good I think and when I say crank voltage this is when I turn key to crank but it does not crank
So I got out the jump leads and still same problem
I will be testing the starter tomorrow is there a good way of doing this without removal?
Update
I've tested the started connections
Positive ok
Negative ok
Ignition wire 8 volts which should be battery voltage and getting this when trying to crank and around 2 volts when ignition is on
I put a live wire to the ignition wire and still nothing
I have taken the starter of to bench test and it is working fine
Have no idea where to go from here
Battery is dead
(16-06-2016, 05:35 PM)Coli Wrote:  Battery in dead
Battery was low before I started to test so put jump cables on while I tested it
I would still try with a fully charged battery because jump leads themselves still might not be ebough without leaving them for a while to put some juice back in the battery. If the battery is dead dead then they my not work anyway.
(15-06-2016, 07:44 PM)Simon Mailley Wrote:  Hi guys thanks for your reply
State of Charge Voltage
100% 12.7 - 13.2
75% 12.4
50% 12.2
25% 12.0
Discharged 0 - 11.9 -
See more at: https://www.batterystuff.com/blog/how-to...RtmEm.dpuf
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
