Can anyone tell me if they have had a problem with the engine warning light coming on after aprox 1 mile, just brought a 2004 2.0 HDI had the warning light come on couple of weeks ago and again this week, the first time after turning if would not restart, any idea's.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
You need to get it plunged in ,see what codes come up
Threads: 9
Thanks Given: 316
15
As Johny555 says above but if i was going to have a random internet guess im going for temperature sender - reason they play up quite a lot on the 2.0hdi's other than that bomb proof.
How many miles you done? When was it last given a full service? Does the light go out then come back on when driving?
Threads: 67
Thanks Given: 238
50
Not a guru on 2.0 and maybe a silly one maybe but does it have oil in it ??
Serieal Berlingo owner
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 2
See if you can borrow a code reader from someone. This will give you a fault code that you can look up to locate the problem. I found this really helpful when my engine light came on and meant I was able to fix the problem myself. Plus if you post the code on here there a lot of people who will be able to help and give links to How to fix guides
