USB socket
I have just collected my new Berlingo, 120bhp 6 speed xtr. It has most of the options, including satnav. I have been searching for the USB plug and cannot locate it. It has Bluetooth, so I assume that all connections are via that.
I ended up buying it from a dealer 200 miles away as I saved a fortune on the rrp and a small fortune from getting it locally, as it was a pre reg but still brand new. But I can't really pop back to check with them.
PS Very steep learning curve with new technology!
Cancel my request, found it! After search on forum,
"Have a look at the centre dash console on the passenger side there is a pocket, it should be in there."
(16-06-2016, 06:25 PM)andylobb Wrote:  Cancel my request, found it! After search on forum,
On my B9 Blingo its under the radio on the front of the dash, and works surprisingly well. I find that 8Gb flash drive is about the max from a practical point of view, although the system will handle at least 16Gb....
Richard
Richard
Do all Berlingo's have USB with the radio, or only some models ?
I think only the later ones have a USB, dependant on spec, my 11 plate didn't have one.
[-] The following 1 user says Thank You to andylobb for this post:
  • GerardKeating
Hi my 2012 does not have one either :-(
It has a aux port in the glove box but when i connect to it all i get is a loud clicking noise ?
Is it possible to replace this with USB port ?
2012 Berlingo Multispace VTR 1.6HDI White
(24-07-2016, 01:28 PM)Peter Guy Wrote:  Hi my 2012 does not have one either :-(
Dont think adding a USB is possible without changing the head unit. My 11 plate had the auxiliary port in the glovebox and I connected my phone to this via the ear phone socket on my phone. I could then play music by selecting aux on the radio head unit. I could also use the phone but only by controlling via the phone, the head unit, radio , only controlled volume. Hope this helps.
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
