[Engine] oil leak top of sump
Hello
i've noticed that i have a oil leak on the top part of the sump and there is a screw missing, is there a seal or something that may need replacing? seems to be a slow leak but would like to fix it sooner rater then later
any advice would be great
trying to attach photo now
cheers
Attached Files Thumbnail(s)
That leaks not from the sump. Its coming from the top of the engine.
Rocker box gasket ??
Which engine so you have?
The 1.4i petrol engine has a common problem with oil leaking from the head gasket.
Mine leaks. And some research online showed it is common in the 1.4i
In two minds wether to get it fixed and do the Cambelt at the same time or just leave it and sell as is. The only thing my Berlingo has going for it is the low mileage 42k, though we have put on 15k of those since November. Has had a hard life in Central London for most of its life though!
Silver Berlingo Multispace 1.4i Forte
Last Post: Desdinova
Yesterday 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
