Unplugged Cables
I have a 2009 Multispace which I bought in Feb 2016.
Hi All I discovered two cables under the bonnet with plugs attached which at not connected to anything but do not connect together.
My head lights aren't functioning at the moment but main citreon dealer says that is a fuse box issue which he confirmed by swapping the fuse box out to try.
Does anyone know what these cables are for or where they should be plugged in.
Images attached.
Thanks.
Attached Files Thumbnail(s)
Images ??? cannot see any .....
Cables .. not unusual, probably a generic loom and you don't have some of the " extras " they connect to.
  • BerlingoMultifault
If you mean the plug near brake fluid container thing,don't worry mines the same just a plug dangling think its for a different model.
[-] The following 1 user says Thank You to Johny555 for this post:
Images attached.
(21-06-2016, 10:10 PM)Johny555 Wrote:  If you mean the plug near brake fluid container thing,don't worry mines the same just a plug dangling think its for a different model.
Image attached now Johny555. What you think?
do you have air con fitted ?
2012 Berlingo Multispace VTR 1.6HDI White
(21-06-2016, 10:07 PM)geoff Wrote:  Images ??? cannot see any .....
(22-06-2016, 05:02 PM)Peter Guy Wrote:  do you have air con fitted ?
I don't know. I have a A/C button on the dash. But it doesn't seem to make any difference when pushed.
If there is aircon there will be a compressor near the top of the engine looks like power steering pump, will have 2 thick piper attached.
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
