Threads: 3
Thanks Received: 1 in 1 posts
Hi all,
I'm looking to add a little extra sound to the van as the original system is pony i.e Headunit sub and boxed 6x9s into van.
I have managed to get the head unit going by swapping that red and yellow wire around. However does anyone know if it's possible to get the stalk controls, usb socket and the dimmer/illumination working to my head unit?
Threads: 30
Thanks Received: 99 in 44 posts
Thanks Given: 40
4
Hey
Have you read through the thread car audio Speakers/stereo? On the last page I have written a little about stalk controls. Only certain types of stereo can have them and you also need a special harness for it about £50ish with the patch lead I believe. I'm still trying to save money for the stereo and all that I want... Still at £0 though lol
Lliam
Lliam
70 plate Berlingo
Threads: 3
Hi Lliam, yeah did check out your thread. Did a search on google and it was that thread that lead me to this site.
Don't surpose you know which wiring is for the illuminiation/dimmer. May have to splice to one which goes into the display pannel above.
Also you mentioned problems when installing the sub? I have ran all the required cables just need to connect it all up and don't want to bump into any more surprises so any heads up would be appreciated.
Threads: 3
was looking everywhere for a diagram of the pinouts! Oh right yeah at first I didn't understand what you meant by fire wall, I just went through the rubber bung in the passenger footwell and ran all wires behind glove box along door carpets to the rear.
Got Sub and rear speakers (6x9s) all working now. Much better!!
Next, will have to take a look at that a6 pin. As it's labeled accessories you don't think it would be for the mobile phone microphone or aux ports?
Threads: 30
Thanks Given: 40
4
16-12-2010, 10:31 PM
(This post was last modified: 16-12-2010, 10:32 PM by lemsworld.)
I made the diagrams myself as I found it easier to have on the computer
I couldn't find my way through the passenger side so I went drivers side had to go under wipers then through the wall. I havnt got 6x9's but have the dash speakers which sounds better
A6 was labelled accessories but on my harness the orange wire had illumination written on it and it was A6 it went into. My Sony head unit illuminates fine
Lliam
Lliam
70 plate Berlingo
Threads: 3
Thats right the orange is labelled illumination however at the iso end plug it doen't match to any pins at the citroen end. Think I got that the right way round lol. My headunit illuminates fine, I just want it to dim as it should when the exterior lights are turned on. I could have it set on a timer if all else fails though would prefer it to the lights.
Also another pain in the backside, just bought a 16gb SD card, not cheap, for the unit. Have put music on but unit reads 'read failed'.
Threads: 3
Yeah think you maybe right there. Have tried an old 512 SD formatted to FAT which works but as you say me new one says SDHC on FAT32. Don't surpose theres anyway to change the format or much point? otherwise I'll wrap it back up and give it to the old man for xmas.
Threads: 30
Thanks Given: 40
4
I'm not sure about that. All I know is there's a difference between the two sorry
Lliam
Lliam
70 plate Berlingo
