[Steering & Suspension] Track rod boots
Threads: 15
Thanks Received: 26 in 17 posts
Thanks Given: 25
Location: Blairgowrie, Perth And Kinross, United Kingdom
Hi guys,
2 queries,
No 1 been getting a vibration type noise from steering when parking, low speed turning etc, but only when about 3/4 turn before full lock to the left, no roughness or any other symptoms and nothing apparent on right turns. Plenty fluid in reservoir, any ideas?
No 2 had a look under van tonight and noticed that the o/s rubber boot on the steering rack is split/torn. How difficult is it to replace the boot or is there more to it than that.
Berlingo Enterprise, 1.9 MK 2.
thanks,
Dave.
Threads: 20
Thanks Given: 2,126
18
It'a case of removing the TRE.Count the turns on removal so you don't upset the tracking.I would advise sucking the ATF out of the PAS res,top up & repeat 3 or 4 times every 50 miles or so to replace the old stuff.Should be red when finished whereas the old fluid is probably brownish.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• tanto
Threads: 15
Thanks Given: 25
know how to do the TRE's, replaced them, the discs and pads, wheel bearings, pinch bolts and driveshaft /gearbox oil seal 2 months ago. Was wondering more if the steering gator can be replaced from the TRE end or if the TR has to be separated from the rack.
Threads: 5
Thanks Given: 5
(27-06-2016, 07:36 PM)ron Wrote: It'a case of removing the TRE.Count the turns on removal so you don't upset the tracking.I would advise sucking the ATF out of the PAS res,top up & repeat 3 or 4 times every 50 miles or so to replace the old stuff.Should be red when finished whereas the old fluid is probably brownish.
Sorry for jumping in on this thread, but what would you use to suck out the ATF?
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
With a turkey baster or somthing like that I would think
Thanks Given: 188
23
I second that or a big syringe with a pipe on the end. Turkey baster a quid from a pound shop
Are we there yet?????
Threads: 5
Thanks Given: 5
27-06-2016, 09:38 PM
Cheers Guys ...
Threads: 15
Thanks Given: 25
Ok guys, spoke to a mechanic mate today and he reckons it is a case of removing the TRE and the nut from the track rod, cutting the boot clamps, remove the damaged boot and slip the new boot onto the track rod. Is it that simple ? or is there more to it.?
Dave.
Threads: 20
Thanks Given: 2,126
18
(28-06-2016, 08:14 PM)tanto Wrote: Ok guys, spoke to a mechanic mate today and he reckons it is a case of removing the TRE and the nut from the track rod, cutting the boot clamps, remove the damaged boot and slip the new boot onto the track rod. Is it that simple ? or is there more to it.?
Dave.
What part of my post confused you?
Threads: 15
Thanks Given: 25
(28-06-2016, 09:27 PM)ron Wrote: (28-06-2016, 08:14 PM)tanto Wrote: Ok guys, spoke to a mechanic mate today and he reckons it is a case of removing the TRE and the nut from the track rod, cutting the boot clamps, remove the damaged boot and slip the new boot onto the track rod. Is it that simple ? or is there more to it.?
Dave.
not confused, just looking for a straight forward answer, removing the fluid from the reservoir aint gonna help. Was unsure if gaiter would go on without removing the whole track rod.
Last Post: BigVtwin996
Today 08:25 PM
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
