Threads: 3
Thanks Given: 2
30-06-2016, 07:11 PM
(This post was last modified: 30-06-2016, 07:12 PM by joenh02.)
I have recently noticed a knocking mainly when I turn the engine off or if I am turning in reverse. Anyone had this problem before? If so what could it be? Thanks
Threads: 12
Thanks Given: 16
37
The dog bone lower engine mounting can work loose with time, check the 16mm bolt for tightness, it needs to be very ! Tight.
Sometimes the captive thread strips and you need to replace this with a nut, nylon variety is best.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• joenh02
Threads: 3
Thanks Given: 2
Looks like it's the actual rear engine mount bushes. I don't fancy taking the drive shaft out so how difficult is this to do in place?
