1.9d, even slower than usual..
Hiya All...
  Has anyone noticed that their 1.9d is slower than usual ? It might be just mine but I have noticed that sometimes it goes as expected and sometimes it barely has enough power to rev itself up.. getting to 70 is a matter of maybe, not when.. even putting the clutch in and revving the engine it wont go over 4k and there is no power until 2.5k.. I thought ( hoping ) it might have something to do with the weather...
 Air filter is new, EGR is disabled, only ever used Shell fuel, Oil is new, getting 36mpg when playing up and 44 when normal..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Is it the late one with the ecu on the pass suspension turret? If so try unplugging the air flow meter and see if it goes any better, if nothing changes pull the pipe from the front of the inlet and make sure the air dozer isn't folding shut and blocking the airpath strangling the engine...
Also check the throttle is getting fully open by getting someone to press foot to the floor and see if the pump arm moves any more by hand (don't trap ya pinkys though!)
[-] The following 1 user says Thank You to dumdum for this post:
  • ajcommercial
It is the one with the ECU on the N/S turret, I will try what you have suggested. Now you mention the MAF it makes sense that if it were failing the fuel / air mix would be all over the shop..
If the flap is lose, I'm guessing the best way to secure it is to screw through the outside ? Or remove the flap ?
my van did this wouldnt rev over 4k. my berlingo car revs to near 5....
swapped the mafs round .
revs right through the range.
Captive wishbone nut issue
Last Post: sherpataylor
Yesterday 11:37 PM
hdi fuel filter
Last Post: Daveyboy999
Yesterday 09:30 PM
15inch Steel Wheels with tyres x4
Last Post: killie77
Yesterday 09:19 PM
Yet another reversing camera question?
Last Post: Brixmis7
Yesterday 06:14 PM
coolant leakage
Last Post: Gadgetman
Yesterday 11:53 AM
Key fob programming help
Last Post: Tomcat3
Yesterday 10:39 AM
» Replies: 28
Speakers Question
Last Post: killie77
Yesterday 09:55 AM
Servo no longer manufactured
Last Post: mr bling
Yesterday 09:54 AM
Tyre Question ?
Last Post: killie77
Yesterday 09:45 AM
B9 Camper Build with Step by Step Photos
Last Post: OrtesPL
Yesterday 09:03 AM
» Replies: 85
