Threads: 9
Hi
Any idea if berlingo got in 2016 indirect tpms based on esp/abs sensors not tyre sensor ?
Asking because not sure which one I have .....
Wysłane z mojego SM-G925F przy użyciu Tapatalka
Threads: 15
Thanks Given: 46
5
I was asking my local Cit dealer just this as I have heard stories of spare having no monitor causing warning light to be on with spare fitted & he said that current Berlingo models have abs sensors & do not light warning light with spare fitted.
Threads: 9
I called authorised dealer ..since ca april of 2016 only abs based sensor has been assembled
Threads: 12
Thanks Given: 16
37
The new style tpms tyre valves, do look identical to the normal rubber valves , it is also no easy to replace the stems & at a reasonable cost.
You cannot tell if they are present on the car until the tyre is removed.
They are mandatory on all new cars sold now.
Threads: 9
Call dealer and ask if you don't belive but ask about current production of berlingo not late 2015 etc ..I asked Warsaw main citroen office and my local in Kielce ..both said the same ..esp abs only
Threads: 8
Thanks Received: 4 in 3 posts
Thanks Given: 1
According to Wikipedia indirect tpms is approved and because of it's ease of implementation is now then preferred method. My dealer advised my on my picking up my '16 plate that it was indirect.
Threads: 9
it's cheaper for Citroen...4 sure
