Good morning, I have a 1999 1.9 diesel berlingo van,this morning whilst in the middle of a very busy junction the clutch pedal decided to hit the floor? I found a bit of a white clip on the floor, the clutch has always been stiff in the 3 and a half years I've owned it but has never given me any problems, I only moted it Monday after spending a bit on it, basically what I want to know is, how to fix it and is it a hard job? I generally do stuff myself but I'm no mechanic,
Thanks Sean
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
08-07-2016, 03:38 PM
(This post was last modified: 08-07-2016, 03:38 PM by brodfather11.)
I believe it an awkward thing to do ., never done one myself on a berlingo , pedals bushes usually are. Probably seat out and lie on the floor on your back jobby to see what your doing . Good luck !
If you try it yourself then change the clutch cable also, and make sure the clutch operating lever on the top of the g/box is also free and not sticking. They being partially seized probably caused you bush/pedal to break.
