Reverse camera
Hi all didn't know we're to post this but here goes. I've just bought a tft wireless reversing  camera for my balingo van of eBay came with wire diagrams but it's still away over my head. Any ideas please before I have to pay someone to do it for me
I went off the positive on the reverse bulb and the other I earthed it, the front end tapped into posi on stereo its wired to, mine had little spade thing that pushed into connection block
(15-07-2016, 08:32 PM)finny Wrote:  I went off the positive on the reverse bulb and the other I earthed it, the front end tapped into posi on stereo its wired to, mine had little spade thing that pushed into connection block
Sorry mate but I haven't a clue what it is your trying to tell me. But thanks anyway. They maid it sound like an easy job it probably is for most but these things go way over my head.
I need a proper detailed diagram or video the ones I've seen on utube r somewhat OK but I seem to have to many wires with mine to the onesame I've been watching
Can you post a link or name to the camera you've got, that way we may be able to work something out
(16-07-2016, 07:16 AM)brodfather11 Wrote:  Can you post a link or name  to the camera you've got, that way we may be able to work something out
Yes sure thing thanks. Hope this works if not I'll try something else
http://rover.ebay.com/rover/0/e11404.m43...AGB%3A3160
similar camera I have, the wireless part is the same, and yes my supplied instructions with the camera were useless. ive fitted a bit of ice over the years so I found it straight forward. if your not sure get someone to fit it for you, you will also probably need to wire you headunit up to the reverse wiring too so when you select reverse it comes up on the screen automatically
Hi can you tell me were you connected your stereo to your reverse wiring on the car please looked on here but can't find anyone who has posted it thanks
Most will tap into the reverse light wire at the rear lamp cluster and run a cable to the front for the monitor, or you can find the reverse lamp wire on the sill or at the front corner behind the glove box (from memory it goes via bsi to rear of the car) if I'm honest it's a probably the easiest thing to wire on a car so I'd advise paying someone to wire it for you, run the power lead for the camera to the reversing lamp cluster area and the monitor leads to the passenger footwell, then just get someone to find and solder the power leads in which should be under 30 quid I'd think, I'd prob charge 20 quid for that job as a self employed auto electrician/mechanic because it's a relatively easy job!
i only connected it at the back light, my headunit has a camera button so i didn't need automatic connection
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
Today 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
Today 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
Yesterday 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
