[Steering & Suspension] got a few probs advice needed
hello all just bought a 55 plate partner 2.0 hdi combi, im happy with it but got a few probs i want to sort so any advice helpfull thanks, steering is losing its assitance on 1/4 lock steering wheel is trying to turn right to left about half an inch going round corners, at 1200 revs there a bit of a flat spot. banging noise  sounds like a ball joint gone on offside front think its coming from the top of leg as i drive over slight bump. offside  rear wheel is closer to the back bumper than the nearside, airbag light on, any advice would be  good, ive been in motor trade 29 years, adam
hi, try lubricating the bottom steering column UJ where it sticks through into the engine bay,common issue is when they dry up and start seizing,I thought mine was a fluid problem so I changed the fluid,all it was was the UJ, sprayed with wd40 a few mornings before i went out driving and it was an instant fix,I only used the wd initially to free it off,then used a spray grease...over to the others for the rest sorry ..Ian
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
(16-07-2016, 09:58 AM)ians_lingo Wrote:  hi, try lubricating the bottom steering column UJ where it sticks through into the engine bay,common issue is when they dry up and start seizing,I thought mine was a fluid problem so I changed the fluid,all it was was the UJ, sprayed with wd40 a few mornings before i went out driving and it was an instant fix,I only used the wd initially to free it off,then used a spray grease...over to the others for the rest sorry ..Ian
this seems more like the power steering is going on and off, if i keep wheel turned about 1/4 turn in the same position you can feel the power steering working and not working, but i will try oiling the uj and see what happerns thanks
I also thought power steering,it was mainly at a quarter turn either way,entering or leaving roundabouts etc,I'm doing 3000 a week in mine ,mainly motorway cruising with very little movement of the wheel,also you'll find it's fine when it's raining then gets worse as it dries out again.mines like a new van now,not a 200000 miler :-)
Mine was stiff,sprayed u joints inside the van under steering wheel, and out side in the engine bay its loads better now,I also found when it was raining or damp steering was a lot better,
[-] The following 1 user says Thank You to Johny555 for this post:
  • ians_lingo
(16-07-2016, 01:31 AM)wuppertdupont Wrote:  offside  rear wheel is closer to the back bumper than the nearside.
Peugeot/Citroen trailing arm axles are prone to seizing, collapsing bearings inside the tube. My old 306 did it, my 206 has done it and the berlingo I have now.
I find the trailing arm gets stuck, if left long enough will wear the inner? tyre shoulder. The tyre side wall can also rub on the rear arch liner, as my berlingo started.
A good test is to see if you can fit fingers from the top of the tyre down the side wall. Viewing from the back the wheel might also look at a bit of an angle due to the arm dropped and stuck.
I didn't want the hassle so opted for a recon axle a bit pricey though. You can get bearings and shims but its a fair job pulling them out when i tried years ago.
(16-07-2016, 01:44 PM)ians_lingo Wrote:  I also thought power steering,it was mainly at a quarter turn either way,entering or leaving roundabouts etc,I'm doing 3000 a week in mine ,mainly motorway cruising with very little movement of the wheel,also you'll find it's fine when it's raining then gets worse as it dries out again.mines like a new van now,not a 200000 miler :-)
thanks for your help and advice i will give it a go with oil cheers and report back
so im looking at another axle then, look at wheels both sides os is further back, he said axle had been done at £1000 WAS HE FIBBING
I used imaxles on ebay £250 + £50 postage for a refurb.
[-] The following 1 user says Thank You to bobalobmitchell for this post:
  • ians_lingo
(16-07-2016, 11:29 PM)wuppertdupont Wrote:  so im looking at another axle then, look at wheels both sides os is further back, he said axle had been done at £1000 WAS HE FIBBING
Does the axle look fairly clean with paint still on it ? You might just need to undo the bolts holding it on and check the alignment.
Diesel Filler Cap
Last Post: Matt Haigh
Yesterday 09:21 PM
Handbrake or in my case, not !
Last Post: Martinez
Yesterday 05:50 PM
Oil leak XTR 92 Fap
Last Post: Pid
Yesterday 05:45 PM
Welding sills
Last Post: Martinez
Yesterday 05:43 PM
Tail lights
Last Post: gazahull
Yesterday 01:37 PM
engine temperature cooling fan
Last Post: Oldfella
Yesterday 10:41 AM
newbie
Last Post: fluidityfreerun
Yesterday 08:33 AM
How rare are the sunroofs?
Last Post: ffrenchie
Yesterday 07:02 AM
Just joined and would welcome some advice on buy...
25-06-2019 10:06 PM
Eberspacher or similar
Last Post: bikey
25-06-2019 09:22 PM
» Replies: 34
