Under inflation system fault ..intermittent
Hi
I had 2000km odo xtr from 2016 and have some times such a info on the tablet
[Image: 0c46b6e91cea963c81193bbed7c07837.jpg]
It happens when i plug in key and switch to first position. And it apears sporadicaly hard to say what cause it (handbrake not change anythibg)
Moreover when i check diagnostic folder in my tablet there is no fault. Also citroen dealer had not found andy faults even historic one...any idea what is that ?
Wysłane z mojego SM-G925F przy użyciu Tapatalka
The problem is that its probably new system without "inside tyres"valves basing only on esp/abs parameters
Its some software bug in citroen indirect tpms system (berlingo manufactured from january 2016) ..german fellows recognised problem and probably new ecu soft will be cure for that issue ..till than anyone who expirience short info about tpms system fault should activste door autolock which solves tpms issue.... checked and worked
(19-07-2016, 06:58 PM)andy-M Wrote:  Its some software bug in citroen indirect tpms system (berlingo manufactured from january 2016) ..german fellows recognised problem and probably new ecu soft will be cure for that issue ..till than anyone who expirience short info about tpms system fault should activste door autolock which solves tpms issue.... checked and worked
Glad I read this :Smile just turned my autolock off and just started getting the alarm :Smile Will make a not of this and when I take it in for its first service next year, hopefully it will get loaded up!
An update? Progress?
Last Post: JPCoetzee
Today 10:34 AM
Last Post: jw4821
Today 08:48 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
