[Transmission] Help needed with clutch
Hi all I need a new clutch in my 2.0 hdi berlingo. I have looked at my gearbox and the only code I can see is BE4 but all the clutch kits say BE4R is there any difference between them or is the BE4R kit same as BE4  Huh
Not a clue but if you put your reg in that should give you the correct one
(25-07-2016, 06:12 PM)Johny555 Wrote:  Not a clue but if you put your reg in that should give you the correct one
Hi i have done that on eurocarparts and a few other sites and all list 2 clutch kits BE3 and a BE4R. I assumed with my transmission being stamp BE4 that it will be the BE4R kit but just seeking do clarification really
Sounds like the one then,if unsure can't you get them both,and when its fitted take the other one back,
Be4 clutch is what you need
cheers got it sorted now £80 for the clutch kit £100 to fit it. drives spot on now
(01-08-2016, 11:12 PM)Leelevis Wrote:  cheers got it sorted now ....... £100 to fit it. drives spot on now
   Bargain !
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
