Citroen Berlingo Detail
Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 6
So i finally bought some decent detailing products to clean my van with the whole process took 3 hours and 30 mins. Here are a few products i used ;
Valet Pro PH Neutral Snow Foam
Meguiars Clay Bar
Meguiars Quick Detailer
Morrisons Cheapo Shampoo:lol:
Auto Glym Tyre Dresser
Auto Glym HD Wax
Here are some before pictures
[Image: Bromsgrove-20111001-00690.jpg]
[Image: Bromsgrove-20111001-00692.jpg]
[Image: Bromsgrove-20111001-00694.jpg]
Now the during;
[Image: Bromsgrove-20111001-00695.jpg]
General contamination on the panels
[Image: Bromsgrove-20111001-00698.jpg]
Now after its complete
[Image: Bromsgrove-20111001-00699.jpg]
[Image: Bromsgrove-20111001-00705.jpg]
[Image: Bromsgrove-20111001-00704.jpg]
[Image: Bromsgrove-20111001-00706-1.jpg]
Threads: 20
Thanks Given: 2,126
18
 cratch:If my Berlingo was that clean,I would walk past it in a car park.I like your buffing mop.
Strawberry flavoured windows
Threads: 41
Thanks Received: 31 in 28 posts
Thanks Given: 16
Can I book mine in with you please? :thumbsup:
Threads: 2
Thanks Given: 6
02-10-2011, 06:58 PM
(This post was last modified: 02-10-2011, 07:00 PM by Brad.)
(02-10-2011, 06:49 PM)ron Wrote: cratch:If my Berlingo was that clean,I would walk past it in a car park.I like your buffing mop.
Im quessing you mean the dog:lol: he gave it the last check over to make sure it passed his test haha
(02-10-2011, 06:52 PM)knobblywobbly Wrote: Can I book mine in with you please? :thumbsup:
A few beer tokens and ill be happy too
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
My van had company stickers on, now removed.
Was left with a slight "imprint" where lettering was.
Only visible in certain light, but I knew it was there.
Tried to T-Cut out, but made it worse.
Now has tiny swirlling scratch marks and paint is dull.
This is just on one side, the rest is fine.
Any suggestions, without spending a fortune?
Threads: 2
Thanks Given: 6
02-10-2011, 07:33 PM
(This post was last modified: 02-10-2011, 07:34 PM by Brad.)
(02-10-2011, 07:13 PM)j90xxx Wrote: My van had company stickers on, now removed.
Give your van a clean with 2 buckets (one with shampoo and another to rinse) then use a clay bar to get rid of all the left of dirt this might be why you had swirl marks after you polished it before. Then once its clayed either hand polish or use a cheapo polisher with some Auto glym super resin polish, this should bring it back to new
http://www.ebay.co.uk/itm/MEGUIARS-QUIK-...2567f1b5de
http://www.ebay.co.uk/itm/AUTOGLYM-SUPER...2a1449f77c
Hope this helps
The following 1 user says Thank You to Brad for this post:1 user says Thank You to Brad for this post
• j90xxx
Threads: 63
Thanks Given: 410
(02-10-2011, 07:33 PM)Brad Wrote: Give your van a clean with 2 buckets (one with shampoo and another to rinse) then use a clay bar to get rid of all the left of dirt this might be why you had swirl marks after you polished it before. Then once its clayed either hand polish or use a cheapo polisher with some Auto glym super resin polish, this should bring it back to new
I've read about using clay bar but how exactly is it used and does it really fetch the proverbial off a blanket???
Threads: 2
Thanks Received: 6 in 4 posts
Thanks Given: 2
compound is really what ye need as well and either hand buff or machine buff it in, that will remove the imprint, autosmart r2 might do it, r3 is a bit rougher but will also do
The following 1 user says Thank You to Wavin for this post:1 user says Thank You to Wavin for this post
• j90xxx
Threads: 101
Thanks Given: 384
Cheers Brad.
The bonnet has a dull finish,too. Not scratched, just dull.
Will clay work on this as well?
Think my bottle of T-Cut is about 25 years old. Don't think that helped.  illyme:
Threads: 50
Thanks Given: 743
(02-10-2011, 09:41 PM)j90xxx Wrote: Cheers Brad.
Cutting compounds do deteriorate with age. I have two bottles of Farecla which have definitely 'gone off' with age.
The stuff has visibly separated and is no good any more.
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
