Threads: 16
Thanks Received: 54 in 17 posts
Thanks Given: 4
8
27-07-2016, 06:21 PM
Thought I would replace my brake pads as I saw a special offer on brake pads & disc with free delivery
but when I looked at the web page there was two sizes. . .
Thickness [mm]19/ Width [mm]137/ Height [mm]52 & Thickness [mm]19/ Width [mm]137/ Height [mm] 57
the same with the Disc
Diameter [mm] 283 / Brake Disc Thickness [mm] / 26 Height [mm] 34.2 & Diameter [mm] 266 / Brake Disc Thickness [mm]22 / Height [mm] 34.5
Trying to find out what is the right size to order
2007 Berlingo desire 1.6hdi
Threads: 9
Thanks Given: 316
15
Only way to be sure is take a wheel off and measure a disc, or take a chance and call Citroen and ask their parts department.
You just need the diameter of the disc and they will supply pads to fit
Threads: 16
Thanks Given: 4
8
Would it be ok the order the pads & disc providing they match each other even if it not the original size that fitted now? guess it a 50/50 chance of being right . .the disc (2) only costing 30 Euro and pads (4) 9euro which I think is a great price
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
No you need the same or your carriers won't fit or the pads will be way off the disc, you can change it but it's new caliper and carrier time plus bleeding them up
Threads: 11
Thanks Given: 16
8
Pads for 9 euros doesn't sound particularly good when they are the items that save your life should you need to stop! I don't get why you'd ever skimp on brakes, same with tyres!
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Yep, Alarm bells would be ringing for me too. (unless they are a known good brand with a genuine good price)
Threads: 5
I'd buy local. 3rd time lucky from ECP. First set both pads and discs were to big, second set of discs were the right diameter but hub spacing was wrong, 3rd set fitted. All three was listed for my Partner.
