  • 7 Vote(s) - 3.71 Average
Electric Windows
Question
New to the Citroen range and Berlingo model. Just bought a 1.9D Multispace and found an odd problem or 2.
The passenger side electric window doesn't work. Wont go down when the button is pressed any ideas? The drivers side works fine.
Fuse? Motor? or Wiring?
Any help appreciated
Andy aka Newspaperman
Hi. At first check fuse
(02-10-2011, 08:04 PM)pk7478 Wrote:  Hi. At first check fuse
Do you know if the elactric windows are both separately fused?
"Plus" comes to buttons and control box via one fuse in BSI.
BSI??? wont be the fuse then if drivers side working.
Where is the fuse box located?
Right took centre dash apart and found that 12volts is being supplied to both switches. Swapped the switches over and still same.
It must now be the motor/mechanism itself or a wiring fault
Had a go at the window mechanism today no wonder the window does not work. I removed the door card and noticed straight away what the faults were.
1. The motor was disconnected
2. The window glass assembly is being held up and chocked by 2 lengths 3x2 studding
3. White plastic bits in the bottom of the door
4. All window cables loose
Does anyone know can it be repaired or am I looking at a new regulator assembly? Has anyone fitted a regulator? What is the procedure do we have a how to on this?
Smile
Do you understand what do you need to replace? Smile
No advice needed
(16-10-2011, 05:54 PM)Newspaperman Wrote:  No advice needed
Does that mean you've fixed it or taken the vehicle back from whence it came?
See, I couldn't do that. If I sold a car with that sort of bodge on it I'd have to tell the buyer.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
