[Steering & Suspension] Steering wheel
Hi guys picking up my 2009 XTR tomorrow and previous owner was prone to picking the steering wheel whilst sitting in traffic. So I'm left with a wheel looking like mice have had a little nibble.
Would quite like to change but finding it hard to locate 2nd hand, so it's looking like a wheel cover, has anybody used the slip on type, can't be arsed to spend hours sewing the leather job?
Thanks in advance
Got one on mine bit tight to fit buts its OK,also makes the wheel feel bit fatter,gives more grip to,
(10-08-2016, 07:40 PM)Johny555 Wrote:  Got one on mine bit tight to fit buts its OK,also makes the wheel feel bit fatter,gives more grip to,
Hi seen one in Halfords slip on is that where you got yours?
No,some other car shop ,I had one on my old van,so I always use them now,
I got mine from Halfords, I wanted a thick one due to Rheumatoid Arthritis, does the job perfectly.
I think this is the one.
http://www.halfords.com/motoring/car-acc...over-black
Multispace B9 2009 1.6HDi
I have had 2 of these in 2 different cars: in a xsara Picasso, and in this case the wheel cover was loose, and it was horrible; and now in my Pug Partner. the one in the picasso already came with the car, and because it was so loose, I ended up removing it, it was a security hazard. The one I have in the Pug is really tight. It was hard work to fit in, I almost had to get these bicycle tire fitting tools to get it on the steering wheel. It has some leather, so it is more comfortable to the touch, and yes, the wheel is now very thick.
(11-08-2016, 04:49 AM)Luis Rosa Wrote:  I have had 2 of these in 2 different cars: in a xsara Picasso, and in this case the wheel cover was loose, and it was horrible; and now in my Pug Partner. the one in the picasso already came with the car, and because it was so loose, I ended up removing it, it was a security hazard. The one I have in the Pug is really tight. It was hard work to fit in, I almost had to get these bicycle tire fitting tools to get it on the steering wheel. It has some leather, so it is more comfortable to the touch, and yes, the wheel is now very thick.
sounds good Luis, can you remember where you got it from?
Got mine frim The Range
http://www.therange.co.uk/search?asug=&l...ring+wheel
Hides manky steering wheel nicely.
Malcolm.
2001 1.9D Multispace.
The last one was here in a German autoparts shop nearby. I do not remeber the brand, sorry.
Or Peugeot 207 wheels are identical. I got a nice leather one for a tenner.
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
