  • 30 Vote(s) - 3.17 Average
Radio Power Issue
Hi
I have seen numerous radio problems within the forum but none that pertain to the problem i'm having.
My radio will not work. I have checked the fuses but this hasn't solved the issue. When you press the power button you can hear a brief noise that sounds like it's loading a CD but nothing else happens. There is no visual display on the dash to say it's powered on or anything.
Been struggling with this for a while now and would appreciate any help.
Many Thanks in advance
Is this the original fitment radio?
If so, I had this with mine when I bought it. It is caused by it having been removed and replaced (previous owner had an aftermartket radio). The original is "coded" to the vehicle, so you need the numeric code to enter (anti-theft device), the previous owner may have it or it might be written in the handbook etc. If you don't have the number then it needs to be reset by Pug/Cit. There are websites that claim to be able to supply the codes for you. Or perhaps someone on here has access to the information you need.........PK???
My 2001 & 2004 Multispaces have coded radios. The 2001 is coded and needs a 4 digit code to be input - it will power up in another vehicle. The 2004 is directly coded to the original vehicle - no security code input - and will not power up in another vehicle.
You don't say if the radio you have is the vehicle's original fit radio, a Citroen radio from another car or an aftermarket radio.
Dave
Berlingo Multispace 2.0 Hdi (04) - 238K@43mpg - 205/60HR15 XL tyres all round
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - SORN & still 15° retarded...
Xantia 1.9TD Temp2 Estate (97) - 208K@42mpg - SORN & no turbo boost...
Hi
Yes the stereo is the original. I did purchase the vehicle from someone else but can't see if they've had the stereo out.
There is no digital display on the dash so how would i input the code?
I do belive the code is in my handbook.
Just to add some further info.........
The radio did work at some point but intermittently. There was an issue with the interior electrics at the same time as they were also intermittently coming on and off on their own.
Since the lights stopped coming on and off, so too did the radio.
The electric windows work fine.
(06-10-2011, 08:46 PM)bushpig Wrote:  Just to add some further info.........
Which interior lights were faulty ?
Can you upload a picture of your radio
I assume you have a 2.0 HDi
if so does it have ABS ,ESP and what gearbox is fitted ?
is it a Van or Multispace ?
2003 Citroën Berlingo 2.0HDi Multispace Desire
[/quote]
[/quote]
Hi
I apologise as the car in question is my partners and i have given the wrong info.
Berlingo Multispace 2.0HDi
NV04 plate
No ABS or ESP
The problem with the interior lighting affected all lights whereby the lights in the boot would come on periodically, sometimes altogether or just individuallly, even while driving.
[Image: photo.php?fbid=2257366867272&set=a.15326...=3&theater]
Thats the pic of the radio.
Unsure as where to get the g/box number. Not printed in any of the log/handbooks.
VIN do?
[quote='Coco' pid='10668' dateline='1317716209']
On a different note.....do you know how i can remove the radio cassette player. I am assuming it to be factory fitted. It too does not have a code and i want to put a CD radio in Thanks a lot
Stephen
[/quote]
Hi
NV04 plate
No ABS or ESP
VIN do?
[/quote]
can you upload picture again
can you see it now?
Attached Files Thumbnail(s)
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
