2 brake ligths blown less than year after last ones
Howdo.
Couldn't believe it when a friendly copper helpfully pointed out today that both my brake bulbs had gone, I only had them changed late last year!
Is it just bad luck or likely a symptom of some underlying problem?
Would I be better considering longer lasting LED replacements, are they legal, if so can anyone recommend any from Amazon?
Start simple check your fuses first - replace blown bulbs with a good quality brand of standard bulb - then take it from there.
  • Metal Mickey
Thanks. Is there any point spending a little more on LED in the hope of longer life?
LED lamps can cause problems and generally not worth the hastle on things like stop lights IMO.
I do believe some of the lads have fitted LED's with varying results but a decent standard lamp should last between 20-40k depending on use.
  • Metal Mickey
Emissions fault.
Yesterday 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
