[Engine] wont start
Shocked
Can anyone help me with this please my 2001 berlingo van won't start .I can't get a diagnostic reading I have checked fuses but still no joy. Engine is turning over fine but won't fire?
Errmm. No, sorry-crystal ball is not quite making it tonight so you will have to tell us what engine.
  • moocha
Col thanks for a reply its the 1.9 hdi done 180 00 but van has been superb for me, going to change crank sensor today but still can't understand why no reading on diagnostics Any help would be appreciated thanks.
It won't be .1.9 hdi,its 1.9 d.or 2 Lt hdi.
[-] The following 1 user says Thank You to Johny555 for this post:
  • moocha
Its 2.0 hdi thanks for taking time to look Johnny Ive still got same problem we've changed cam sensor no luck still no reading on diagnostic won't connect tried a bulb in injectors and it shows no sign of any power so any ideas pls.Could it be immobiliser?cheers
Daft question,have you checked all fuses? No good just looking at them put a test light on each side of the fuse,or could be fuel pump,filter,is battery good?you need a good battery and starter to spin the engine over fast enough , hdi engine doesn't really need glow plugs not this time or year anyway,it needs a good fast spin over on the engine
Johnny checked fuses, not checked pump our next route even thought of ECU? But why no power at injectors? Any ideas cheers
Relay or fuse?,or fuel pump? You say you have changed crank sensor?
Yes mate changed crank sensor pump ok just won't have it. Ive got an auto electrician coming out tomorrow mechanic could not diagnose problem cheers
What diagnostics are you using? Can you get live data and see what the rail pressure is when cranking?
Is the cam belt OK? (ie not snapped)
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
