  • 21 Vote(s) - 2.71 Average
Clutch problem
Hi all.
after searching this forum ive decided to post my exact problem and ask for help.
now recently my clutch pedal became very stiff to press down without the key turned in the ignition..this never happened before as i always fully depressed the clutch before i turned on the engine as a habit and safety procedure. this hasnt been a problem but now im getting clutch judder in 1st 2nd and 3rd gear changes.
im hoping this is just a clutch cable problem..which is where i need help.
all i could find was this in the manual section
4.1. Cable operated clutch control
Check : The routing of the clutch cable.
Check that there are no points of resistance .
Replace the clutch cable (If necessary).
sooo, how exactly do i check the cable..where..how.
and if need be how do i replace..ive searched youtube and google but nothing specific..pictures would be great..or a detailed explanation if anyones got the time.
anyways.thanks for reading. hope you can help.
Don't know what engine / box you have but to check the cable is very easy.
Open the bonnet and look at where the cable exits from the pedal box through the bulkhead. The cable then routes to the underside of the crossmember below the steering rack. At this point the cable is in a 'plastic' housing and clips to the crossmember in 2 springy metal hoseclips. The cable then routes in an arc to the bracket retaining the cable at the gearbox end. It is worth getting your head in by the cable mounting point on the pedal end. There is a spring and plastic 'piston' arrangement which acts as a return spring. This plastic and spring 'piston' arrangement can bind making the pedal return very 'notchy'. I have replaced the cables on both bingo's I've owned and it has vastly improved the clutch action. The cable can be changed without the use of any tools. I haven't experienced any great judder in the past except when the release bearing started to fail before completely failing (Its a @&*t design). Also see other post about checking mounts.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
[-] The following 1 user says Thank You to divingscubaboy for this post:
  • JAYJAYBEE
(04-10-2011, 07:26 PM)divingscubaboy Wrote:  Don't know what engine / box you have but to check the cable is very easy.
THANKS FOR THE REPLY DOOD.
yea the clutch has gone very notchy, it meets a little resistance then clicks down which makes me think its just a cable problem although the persistant judder is worrying. ill check it out tomorrow and see if i can get a new cable.
btw just for record i have a 1.9 600D X
ok ive got the clutch cable out and lubed it up summat proppa. Thing is i put it back in, pressed the pedal down a couple ov times and the spring and black plastic fork thingy popped out and the fork has snapped.
However the clutch still works without these parts and the judder is considerably better. What function do these serve, how dangerous is it driving without these parts?
Is the broken part the spring assembly on the clutch pedal? If it is you really want to get them replaced asap. If they're not replaced it could cause the release bearing to drag slightly. The release bearings are crap because they're made from a lot plastic which wears and melts leading to failure. I have tried lubing the cables in the past and it works for a few weeks then gets sticky again. Bite the bullet and replace the cable and the broken plastic springy fork thingy you referred too.
triangle light
Last Post: Buki
Today 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
