Heated rear window switch
I have a 2009 B9 van with solid rear doors yet have the above switch, it lights up when you press it but seen as I haven't used the van in the winter yet I'm not sure what it does, will it likely heat the mirrors or even the front screen although I thought Ford had the patent on this.
I'd guess it would turn on the heat for the mirrors. You can pop one of the mirrors out and see if it has an electrical connection. Would doubt that the front screen is heated by anything other than the car heater.
The button also turns the side mirrors heating/defrosting..
Yup heated mirrors for winter Smile
Thought it would be the mirrors. For the handles I recommend bluetac and stanley knife blades, just remember they are there.
I left my van in a dodgy area once and came back to fund dogshit smeared all over the handles and windscreen. I was not bleeding well happy!
Sent from my MotoE2(4G-LTE) using Tapatalk
French Electrics......Grrrrrrr! Dodgy
(23-08-2016, 10:37 AM)Sootyfoot Wrote:  I left my van in a dodgy area once and came back to fund dogshit smeared all over the handles and windscreen. I was not bleeding well happy!
Are you sure you were not having an affair  Dodgy Wink
Very sure! I was fitting a kitchen!!!
(23-08-2016, 09:22 PM)Sootyfoot Wrote:  Very sure! I was fitting a kitchen!!!
Are you on the level  What tool were you using did you use the front or the back door . Wink Wink
  • Sootyfoot
Lol. All Makita. And her husband was there. Both in their late 70's!
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
