mikeydasilva
Unregistered
HI ALL IM PLANING TO FIT A PARROT MKI9200 AND WANTED TO GET BEHING DASH GLOVEBOX ETC ETC BUT CANNOT FIND ANY WAY TO OPEN THEM CAN ANYONE HELP OR PROVIDE A GUIDE, MINE IS A 55 PLATE BERLINGO VAN WITHOUT PASSENGER AIRBAG OS I HAVE THE HOLE ABOVE THE GLOVE BOX I TOOK OUT THE 4 SCREWS AND PULLED IT FOWARD A BIT BUT IT WONT GO ANY MORE FOWARD AND I CARNT EVEN PUSH IT BACK
THANKS
Threads: 30
Thanks Received: 99 in 44 posts
Thanks Given: 40
4
22-12-2010, 06:48 PM
(This post was last modified: 22-12-2010, 06:51 PM by lemsworld.)
I've not been able to remove my glove box when I've tried before. that is helpful to know
Lliam
Lliam
70 plate Berlingo
Threads: 147
Thanks Given: 263
11
Thanks pk747, brilliant! Hope this forum starts to solve more problems.
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
Andre. I hope. But as we see, there're not so much people in a forum.
I don't know why, but i suppose that in UK Citroen's dealers works better than in my country.
And because of this, i think, not so much people have questions. Am I right?
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
A word of warning from experience. When you remove the glove box be very careful not to break the white plastic pins. They are the crappiest plastic possible and cost £9 each from a stealer.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 63
Thanks Given: 410
(27-02-2011, 11:00 PM)divingscubaboy Wrote: A word of warning from experience. When you remove the glove box be very careful not to break the white plastic pins. They are the crappiest plastic possible and cost £9 each from a stealer.
Might be cheaper from a Peugeot garage ????
I found that with engine cover knobs for mine....
Threads: 27
Thanks Received: 7 in 7 posts
Thanks Given: 2
I’ll revive this one. Tried to get the glovebox out in my 01 2.0hdi. It’s got a lid on the top part which seems to be moulded into the main dash, but the shelf underneath is what I want to remove. I’ve taken the screws out of the top and the 2 hidden screws underneath but can’t get the thing out. Top part moves forward but stuck fast at base. There’s a panel on the lower part of the shelf which seems to hold it in but can’t figure out how to remove it.
Threads: 27
Thanks Given: 2
Removed glovebox on my 2001 van. No pins under dash, but there are 2 torx screws. You need to lie on your back to even see them, but once removed glovebox came out easily
