[Warning Light] STOP & Brake warning light
I have just changed drivers side brake cylinder and bled brakes....the handbrake works real good and the brakes feel firm, the pedal doesn't move when my foot is hard down on it...but the stop warning light is on and the brake warning light too... I checked level of brake fluid n topped up as I bled...
Does anyone e have any ideas????
The van is a 2006. 1.9D. Non turbo Berlingo
Thanks in advance!
Sooty
French Electrics......Grrrrrrr! Dodgy
There might be nothing wrong, they are known for being very sensitive, I found that hilly or windy twisty roads made mine go off but it stopped after I topped it up... is the light constantly on? mine usually went off a few miles down the road...
[-] The following 1 user says Thank You to miccheck1516 for this post:
  • Sootyfoot
Yes. I drove about ten miles after I read your post. Job done. Thanks for the reply. I thought I had buggered something up!
Sent from my MotoE2(4G-LTE) using Tapatalk
mine used to drive me nuts,if it came on I had to stop,even though you know there's nothing wrong,i ended dripping fluid in to nearly the top of the filter,mine also came on after a spell on yorkshire dale roads etc,been ok for over a year....touch wood :-)
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
[-] The following 1 user says Thank You to ians_lingo for this post:
  • Sootyfoot
Aye mine is filled well past the max also...
Sent from my HTC One_M8 using Tapatalk
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
