oh s**t!! ÑOW I got ELECTRICAL Gremlins
Sad
Okidoki folks..well I tried to be a clever bugger and fit a COB LED strip in the back with dimmer for when I'm camping...
Next thing I know..no interior lights...maybe I shorted summat?
So...I check all fuses...seem OK.
So.. I then replaced them all with "when they blow they glow" type fuss that have an LED that shines when it blows to make fuses easier to change.
Shortly after the fuse for I interior lights blew..so I replaced it...problem is now my side lights don't work unless key is I. Ignition..the central locking does not work unless I lock with dash button n then get out and manually lock drivers door...and...when I start the van the needle on
the dash when I put the key in flick downwards with an audible clu k then back up...this includes fuel guage
Also if i turn key off fast the rev counter sticks at 1000 but if I turn it off slowmit drops to zero..
What have I fuggered up now?
Please can anyone help?
Sooty
French Electrics......Grrrrrrr! Dodgy
Bsi reset might help ,you sure fuses OK?,a tip but a bit late don't play with French electrics..
[-] The following 1 user says Thank You to Johny555 for this post:
  • Sootyfoot
Where is your 12v feed for the new light coming from?
Sent from my HTC One_M8 using Tapatalk
It's fixed!!! There was a fuse làbeles HS or SH one fusebox..verdigris on it was stopping contact...switch cleaner n scotchbrite sorted it..just one of those coincidences!!
(01-09-2016, 10:01 PM)Sootyfoot Wrote:  It's fixed!!! There was a fuse làbeles HS or SH one fusebox..verdigris on it was stopping contact...switch cleaner n scotchbrite sorted it..just one of those coincidences!!
Happy days glad you got it sorted
[-] The following 1 user says Thank You to Delfox156 for this post:
  • Sootyfoot
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
