Threads: 23
Thanks Given: 46
5
I don’t think the 'joystick' is meant to operate in the 6 o'clock position
Mine only works if I move the stick to the appropriate position for each mirror.
i.e 2 o'clock for the drivers side and 10 o'clock for the passengers side.
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
Hi if you go into the fuse's box in the glove compartment pull the cover off you will see a small smooth cover if you pull that cover you will see some more fuse's the one to look at is F4 15 Amps for the folding mirror's do the mirror's fold when you lock the door's if so it's not the fuse .
Threads: 20
Thanks Given: 2,126
18
I thought the 6 O/clock pos folded the mirrors?Will check tomorrow.
Strawberry flavoured windows
Threads: 23
Thanks Given: 46
5
Oops .....of course that’s right Ron. My apologies to the OP. I read what I thought he had written, not what he had written.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• ron
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
05-09-2016, 08:52 AM
(This post was last modified: 05-09-2016, 08:52 AM by Luis Rosa.)
mine is a 2011 partner tepee...and my mirror switch does not turn to 6 O´clock position...just left (10) and right (2), for left and right mirror adjustment...
auto folding can be inactivated with diagbox...
but I just love it...I just have to look at the car to realize if the doors are locked or not...
