instrument panel
Hy Everyone
I am new here and i have just bought a berlingo M49 from 2001 1.9 and i have the followings problems in the instrument panel<
a) The rev counter doesn t work
b) the speedo tachometer says the speed but the total millage appears with the number 600000 and the partial trip doesn t work at all as is all the time showing 0
c) the temperature gauge starts  more or less at 3/4 and i turn off the engine doesn t come to start position (0)
Can someone help me please as i have the car for 2 days only and i don t know much about it!
many thanks for your help
(03-09-2016, 08:43 PM)Rui Peters Wrote:  Hy Everyone
It might be worth doing a BSI reset to see if that helps. Im not sure exactly how its done, its probably covered in the forum try searching for BSI or RESET. involves disconnecting and reconnecting the battery in a certain way.
HTH
2012 Berlingo Multispace VTR 1.6HDI White
[-] The following 1 user says Thank You to Peter Guy for this post:
  • Rui Peters
HTH
Many thanks i am going to try that
Hy Again
No y try to reset the BSI but it doesn´t work so i am again starting from 0 , Can someone help me please!!!!
It's a bit old to have a bsi if I'm honest, if the speedo works fine it's down to the clocks for that and I'd suspect your your other issues will be sorted then, but if not you need a new clock anyway to fix the trip... Start there and see what gives after...
All your sensors etc are wired individually, speed sensor has a physical wire from sensor to clocks (420 from memory, how sad!) as does the temp sensor aswell (green sensor is engine management, black is clocks, brown is aircon from memory!) later vans used one sensor and put the info on the can network for all systems to use one sensor including the clocks, hope this helps!
Hy
many thanks for your reply!! i am completely new to berlingos as i only have the van for one week so my knowledge   of the car is pretty low, anyway i am doing a lots of things in the van and i figure that i have to had a look in the clocks(when i finish the others stuff). By the way i forgot to mention i also don´t have interior lights, and central lock (i presume the car as central lock no?) so any help and clues from you i most appreciate.
kind regards
peters
Sounds like you maybe have a fuse gone, fix the obvious broke stuff first as various supplies are shared by all manner of odd things in berlingos...
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
