Van service
I have a 2011 Berlingo with 25000 on clock, it is the 1600 diesel model. Can anyone tell me what I need for its yearly service? Thanks in advance. Mark
How long ago and with what mileage was it last serviced??
It would have Bn year and a half ago probably 19000 miles
Well, you're well over due for an oil and filter change. The 1.6 HDi's are really sensitive and need regular oil changes with oil that matches the PSA spec to avoid trashing a turbo. I change my oil and filter every 9000 km. Not sure what type of fuel you use but a fuel filter might be in order too. Give it a once over and see if any crap has collected in the filter housing. Have a look at the cabin air filter (and pollen filter if you have A/C).
Thanks for that, much appreciated
Oil - Oil Filter - Air filter - Pollen Filter - Fuel filter - check your auxilary drive belt as well for splits and wear.
worth checking anifreeze as car is 5 years old might need changing - Power steering fluid and brake fluid levels.
2012 Berlingo Multispace VTR 1.6HDI White
[-] The following 1 user says Thank You to Peter Guy for this post:
  • ron
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
