martix joint leakage
Hi I have a coolant leakage on the joint between the heater matrix inlet on the bulkhead inside the bonnet and the pipe. It drips when the engine is cool and stops when it warms up. Now am at loss which one to replace. The matrix is new having replaced it last year and the pipe still looks new and last week I fitted new o ring seals.
(06-09-2016, 07:02 AM)Civvic Wrote:  Hi I have a coolant leakage on the joint between the heater matrix inlet on the bulkhead inside the bonnet and the pipe. It drips when the engine is cool and stops when it warms up. Now am at loss which one to replace. The matrix is new having replaced it last year and the pipe still looks new and last week I fitted new o ring seals.
Problem solved. The matrix was of non genuine quality and and there was an issue with the sealing between the O - ring seal of the hoses and the matrix joint on the inner side. A genuine Valeo matrix did the trick and no more leakage
[-] The following 1 user says Thank You to Civvic for this post:
  • brajomobil
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
