09-09-2016, 08:42 AM
Hi Guys. A couple of weeks ago whilst travelling, down a very rough lane i managed to knock my Air Filter hard enough to break the brackets connecting the filter box to the car and also put a big hole in the side of the filter box. The upward impact knocked the intake air hoses off their mounts and the base of the filter box was brokenAs I was right out in the sticks i had no choice but to bodge a repair which meant that the filter box is now hanging on cable ties and the various holes repaired with 'battle tape', sticky backed aluminium sheets. I was quite happy with the repair considering the limited facilities available and have been trying to source a replacement air filter housing without spending a fortune.
Since this knock though the car has not been running too well, rougher/lumpier than usual and in the last week has begun cutting out. At first i suspected air in the system (and still do) as it was cutting out on hills, particularly long hills, however, having sealed a couple of places that i thought the leak may be coming from it now copes with hills with little trouble but is still cutting out about once or twice every 5 mile trip or so, but it now cuts out on level ground, sometimes as i ease off but sometimes as i am just driving at a constant speed i just lose power, the car starts to slow down and then, more often than not, cuts out. It always restarts, usually after a couple of attempts.
Reading the various threads about this type of (seemingly very common) fault, I am now wondering if the damage to the air filter housing or associated bits (MAF) could be causing the ECU to cut the power. I'm not very good with the electronic bits of cars so any advice about what could be causing this and how to test the relevant components would be appreciated.
Also, what is a good way to test the plunger type hand primer for leaks. Sometimes it seems to pump until it gets quite stiff, other times it doesnt seem to be doing anything at all.
3 times now ive thought ive found the fault/leak, seems to be fixed for a couple of runs and then starts playing up again, so what am i missing?
Thanks in advance.
Thanks in advance.
