11-09-2016, 11:25 AM
Driving along in slow traffic after a medium-sized (50miles) journey the oil light suddenly came on in my 1.6HDI Berlingo van (2007). Realising this was serious, not just a random glitch, I drove 200yds and pulled over in a retail park and turned the engine off. Before doing so I noted a rattling sound coming from the engine compartment. After waiting 5 minutes or so I started the engine again, and again the light came on plus the rattling sound. Checked to oil level - it was high with no leak visible. Called the AA and was later towed to a nearby garage.
What the garage discovered was:
- Turbo completely seized
- Low oil pressure, possibly due to broken oil pump
- Rattling sound coming from running gear in top of engine (likely to be damaged)
- Oil filter full of "iron filings" even though it was changed only 4-5000 miles ago
The key thing was though that they found the oil filter was incorrectly fitted - it has a spigot which should have been located in a special hole but wasn't.
Could this have been the cause of the engine failure? ie. filter misalignment not enough to turn pressure light on but enough to cause oil starvation. This causes excess wear on running gear causing "iron filings". This eventually causes oil pump to seize, taking out turbo? Any other ideas?
(Unfortunately it was me who changed the filter!).
