Alloys
Hi I am new here.
I have a Peugeot Partner Tepee 2011 wheelchair conversion,it has 205/65/15 steel wheels.
I am thinking about fitting a set of alloys from a 307,with 205/55/16.
The offset is different steel 27 alloys 34,would I need to use wheel spacers,is there anything else I would need to consider in fitting these alloys.
Thanks Alan.
I assume you are swapping the tyres over?
I personally wouldn't drop 10% aspect ratio just to have Alloys.
Silver Berlingo Multispace 1.4i Forte
(11-09-2016, 07:20 PM)SilverLingo Wrote:  I assume you are swapping the tyres over?
I am thinking of swapping the steel wheels with 205/65/15 tyres  to alloys with 205/55/16 tyres.
You will require the proper wheel bolts for alloy wheels.
So you are leaving the 55 aspect  ratio tyres on?
Bad idea in my opinion.
205/55/16 will be ok, they are 2.47% out, I use this when changing tyres about http://www.etyres.co.uk/how-to-change-your-tyre-size/
i put a set of 8x18s on mine lol
Eolys replacement tank
Last Post: Harrythephot
Today 12:02 PM
Today 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
