Steering grinding when full lock or going slow and turning left
Hi my berlingo 1.6 diesel is making a grinding noise when in full lock or when going slow. This is far worse when left turning. The van steers ok but the grinding can be quite loud from inside. The garage had a very quick look this morning but not on the ramp. He said he dosnt think it's the rubbers and mentioned could be the steering rack which I know is pricey. Any ideas as new to this forum cheers.
Sent from my SM-A300FU using Tapatalk
Check the driveshafts as well ... oh and welcome !
  • strepcil
The bloke I bought car off has just had a quick listen and is adamant the steering rack won't be damaged. He seems to think could be the suspension bushes under bonnet. It's not knocking at all so am hoping it won't be anything to serious. Thanks for reply
Does it make the noise only when you're turning the steering wheel, or does the noise happen when the steering wheel is still and the car is moving?
  • strepcil
(15-09-2016, 10:51 AM)cancunia Wrote:  Does it make the noise only when you're turning the steering wheel, or does the noise happen when the steering wheel is still and the car is moving?
Hi it's just when turning. Mostly when been turned to the left but also slightly to the right. When moving at speeds this sound hardly appears but loads worse when going slow around sharper corners. When it kicks in I can stop the car and you can hear it stationary when slight turns on the steering wheel. When I start car in morning it won't happen until I have drove around a few corners then the grinding groan sound comes back as normal. Cheers
If it only happens when you turn the wheel, chances are that the bearing at the top between the spring cap and the suspension strut have seized or failed. This happened on my Volvo. Not sure how common it is on the Berlingo though.
Here's a nice picture in flebay
http://www.ebay.co.uk/itm/Citroen-Peugeo...SwQJhUjb69
  • strepcil
(15-09-2016, 11:58 AM)cancunia Wrote:  If it only happens when you turn the wheel, chances are that the bearing at the top between the spring cap and the suspension strut have seized or failed. This happened on my Volvo. Not sure how common it is on the Berlingo though.
yes,I've seen them pop up in threads pretty often,sure someone else will be along to confirm...good luck :-)
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
[-] The following 1 user says Thank You to ians_lingo for this post:
  • strepcil
hi strepcil, i had similar prob on my lingo, i changed lower suspension arms, noise gone now ,dont know if this info will help you, regards GWYN
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Thanks bud apreciate advice. Fingers crossed not to much to worry about then. Cheers
Yet another ABS fault
Last Post: leftfootleashed
Yesterday 05:39 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
